Community Member
Jabber for Android Bluetooth not working.
Version 9.1
Calls are working fine but I can't get my bluetooth headset to work with it.  Galaxy S4.  Plantronics voyager pro headset.  Normal cell phone calls work with the bluetooth headset fine.  There is no bluetooth option in the jabber settings.  Any help would be appreciated.
Everyone's tags (4)
1 ACCEPTED SOLUTION
I checked this internally and this is what I found:
Q) Does Cisco Jabber for Android support Bluetooth headset?
A) There is no Bluetooth headset support for the current release.  Bluetooth headsets are supported at your own risk for other applications  on Android, as there is potential interference on the 2.4 GHz band.
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
Tere.
Community Member
Wow, I looked all over the place and did not find that.  Can you post a link to it?
I'm afraid I can't I got that infor from an internal link we have
Tere.
956
