jabber for iphone cucm 8.6
Hi all
I would like to get jabber working on my call manager for my iphones
I cannot see any software under device defaults for this
do I need to download any cop files for this? if so where are the ones for cucm 8.6 ?
cheers
Carl
There's no FW for them, just as IPC, the actual app version determines that. Just follow the configuration guides for Jabber for iPhone.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
what is IPC?
I set up the device on my CM but it doesnt seem to be able to verify, it keeps coming up with verify server name and phone is connected to network!
are there any key settings I need on the profile I need to make it work ? I have it set up as the device
Product Type: Cisco Dual Mode for iPhone
Device Protocol: SIP
Is this correct ?
IP Communicator, what guides for the CUCM, and end user config, are you following for this????
java
java
112
