Jabber for iphone looking for CTLFile.tlv & SEPC42C0391C5C2.cnf.xml
Hi all,
I am trying to get jabber version 9.1 to register with CME 8.6.  When I do a debug tftp events i get the following 2 errors TFTP Looking for CTLFile & TFTP Looking for SEPC42C0391C5C2.cnf.xml
Is there any way to manualy create the .cnf.XML file ? I have very little knowledge of CME as I have only just started studying for the CCNA Voice.
Any help would be much appreciated. I will include the config below and hope someone can point us in the right direction
I am currently running c3825-ipvoicek9-mz.151-3.t4.bin
voice service voip
ip address trusted list
  ipv4 172.16.10.0 255.255.255.0
  ipv4 192.168.10.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server
voice register global
mode cme
source-address 192.168.10.200 port 5060
max-dn 20
max-pool 20
load 7971 term71.default
authenticate register
authenticate realm ************
tftp-path flash:
file text
create profile sync 0001141734766925
voice register dn  3
number 2000
name shaun-iphone 2000
label shaun-iphone 2000
voice register pool  1
id mac C42C.0391.C5D2
session-transport tcp
number 1 dn 3
dtmf-relay rtp-nte
username shaun password 1nsp1rat1on1
codec g711alaw
Thanks Shaun
1 ACCEPTED SOLUTION
Hi Shaun,
In voice register pool insert type for phone, example below, after change no create profile, create profile and reset phones.
registration-timer max 720 min 660
id mac C09F.
type CiscoMobile-iOS
number 1 dn 1
dtmf-relay rtp-nte
codec g711ulaw
J Rosa
Hi Shaun,
id mac C09F.
number 1 dn 1
dtmf-relay rtp-nte
codec g711ulaw
J Rosa
Thanks J Rosa,
I realised after posting that I was running CME 8.5 and CME 8.6 is required ( I hadn't got the option type CiscoMobile-iOS) available under the voice register pool 1. I also was unable to issue the registration-timer max 720 min 660 command.
After upgrading to CME 8.6 and issuing the no create profile and then create profile I still got the error messages, this was even after powering off the iphone for 30 seconds and then powering back on.
End solution was to uninstall the Jabber app on the iphone and reinstall, issue no create profile & then create profile as J Rosa said and all now works like a charm.
Thanks, well happy
345
