Jabber for windows 8
Hi all,
I have 2 questions
1.Which is the best version of jabber which works fine in windows 8 os for 32 and 64 bit and is there any license required for it??
2. Can I install jabber on mac as well? and which ver?
Terry.
1 REPLY
Operating Systems
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/jabber/Windows/9_2/JABW_BK_C9731738_00_jabber-windows-install-config_chapter_010.html#JABW_RF_O9E9CB52_00
You can use Jabber for Everyone and get IM&P, if you want anything more, you do need a license.
Yes, Jabber for MAC, review the same info as above and/or RN for OS compatibility
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
179
