Jabber for Windows Call Pickup Workaround
Anyone know of a workaround to the lack of pickup group functionality in Jabber? Ideally I'm looking for some way of, say, entering a short code which can perform the same function as the GPickUp softkey would... The workaround I have at present is to forward unanswered calls to a hunt group containing all the other staff on broadcast... which is horrible...!
Cheers!
J4W 10.5 was released to
J4W 10.5 was released to Early Adopters this morning - it now has pickup functionality.
Hello there,So, 10.5 is out,
Hello there,
So, 10.5 is out, and the Release Notes does mention Call Pickup as a feature, but I can't get it to work.
Did someone else tried that?
Release Notes for 10.5:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Windows/10_5/rn/JABW_BK_J559CFFB_00_jabber-windows-release-notes-10-5/JABW_BK_J559CFFB_00_jabber-windows-release-notes-10-5_chapter_00.html
You have to modify the jabber
You have to modify the jabber config xml to enable these:
EnableCallPickup
EnableGroupCallPickup
EnableHuntGroup
Kind of obvious huh.. didn't
Kind of obvious huh.. didn't look for new paremeters for this.
That worked out fine! Thanks!
372
