Community Member
Jabber & IP Phone services
We are moving from old telephony to new cisco IP telephony systems 9.1. I want to know the services (ports) which are used between a CUCM server and a IP phone for communication.
Also want to know the services to be enabled for jabber clients on windows 7 & 8 to communicate with presence & CUCM server.
Also want to know the vulnerabilities for CUCM 9.1, so that a precaution can be taken by appluing security patches.on cucm.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Ports used:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/port/9_1_1/CUCM_BK_T2CA6EDE_00_tcp-port-usage-guide-91_chapter_01.html
latest release of CUCM (9.1.2Su1) addresses all known vulnerabilities.
HTH,
Chris
Ports used:
HTH,
Chris
Community Member
thanks for the replly it helped me a lot,
also i found the vulnerabiltied for CUCM 9.1 on security advisories.
162
