Jabber Iphone on CME hangs up call when answered
I have shared lines configured with sccp and sip phones. It was originally working fine for a couple of days but now it has issues. When connected via wifi the Jabber client can make calls and but disconnects when answering a received call. I have it set up on a Samsung Android and after playing with the codecs it seems to be working. On a Iphone 6 when trying to answer a call from the outside it hangs up.
Odd part is I found when removing the "no create profile" under voice register global and recreating it "create profile" it seems to work for a few minutes. Once it starts acting up again I get this error message immediately on the screen when the iphone 6 picks up then hangs up:
I get this error message immediately on the screen when the iphone 6 picks up:
000112: Nov  5 16:15:26.883: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.112 on callID 43 GUID=BC16ED19643D11E4804EAD3623D3BC78
ROUTER-2911#sh voice  iec description 1.1.180.1.13.112
    IEC Version: 1
    Entity: 1 (Gateway)
    Category: 180 (Software Error)
    Subsystem: 1 (CCAPI)
    Error: 13 (Software Error)
    Diagnostic Code: 112
We were running c2900-universalk9-mz.SPA.152-4.M4.bin, I just upgraded to c2900-universalk9-mz.SPA.153-1.T.bin still the same issue. Anyone have any ideas?
voice register dn  1
 number 110
 allow watch
 name Jacks-Iphone 110
 shared-line max-calls 16
 label Jacks--Iphone 110
voice register dn  2
 number 111
 allow watch
 name Tim-Android 111
 label Tim-Android 111
voice register pool  3
 registration-timer max 720 min 660
 id mac 711E.1118.211B
 session-transport tcp
 type CiscoMobile-iOS
 number 1 dn 1
 dtmf-relay rtp-nte
 voice-class codec 1
 username Jack password cisco
 no vad
voice register pool  4
 id mac 1115.D11B.A11C
 type Jabber-Android
 number 1 dn 2
 number 2 dn 7
 dtmf-relay rtp-nte
 voice-class codec 1
username Tim password cisco
 no vad
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
ROUTER-2911#
Can you provide a "debug
Can you provide a "debug ccsip message" and also the voice register global configuration.
Yosh
HTH Regards, Yosh
voice register global voice
mode cme
 source-address 10.10.10.1 port 5060
 max-dn 8
 max-pool 8
 authenticate register
 authenticate realm cisco
 timezone 13
 tftp-path flash:
 file text
 create profile sync 0004095203724312
000196: Nov  5 12:09:02.859: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:9085776815@10.10.10.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.10.3:5060;branch=z9hG4bK+Vwu4kQkwrPFkaSIhNJ9CA~~407
Max-Forwards: 70
To: <sip:9085776815@10.10.10.1>;tag=3629AC-6D1
Call-ID: 38C95545-644511E4-815DAD36-23D3BC78@10.10.10.1
CSeq: 2 BYE
Content-Length: 0
Also: <sip:110@1.1.1.1:5060;user=phone>
Allow: INVITE, BYE, CANCEL, ACK, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 38C95545-644511E4-815DAD36-23D3BC78@10.10.10.1
ROUTER-2911#
000197: Nov  5 12:09:06.127: //198/422A7502815F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/TCP 10.10.10.1:5060;branch=z9hG4bK16510F0
From: "DAVID MARTINEZ" <sip:9085776815@10.10.10.1>;tag=366728-FAF
To: <sip:110@192.168.2.101>;tag=000000000000000a17597bd0-73cfa0a9
Call-ID: 422B112A-644511E4-8162AD36-23D3BC78@10.10.10.1
Date: Wed, 05 Nov 2014 17:09:14 GMT
CSeq: 101 INVITE
Server: Cisco-SIPIPCommunicator/9.2.1
Contact: <sip:F8BC-19B8@192.168.2.101:49325;transport=tcp>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "Jack-Iphone-110" <sip:110@10.10.10.1>;party=called;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.2.0
Allow-Events: kpml,dialog
Recv-Info: conference
Recv-Info: x-cisco-conference
Content-Length: 230
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 19855 0 IN IP4 192.168.2.101
s=SIP Call
t=0 0
m=audio 16388 RTP/AVP 18 101
c=IN IP4 192.168.2.101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
000198: Nov  5 12:09:06.127: //198/422A7502815F/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:F8BC-19B8@192.168.2.101:49325;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.10.10.1:5060;branch=z9hG4bK1671681
Date: Wed, 05 Nov 2014 17:08:55 GMT
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: telephone-event
Content-Length: 0
000199: Nov  5 17:09:06.131: %VOICE_IEC-3-GW: CCAPI: Internal Error (Software Error): IEC=1.1.180.1.13.112 on callID 194 GUID=38C81CF5644511E48157AD3623D3BC78
000200: Nov  5 12:09:06.135: //198/422A7502815F/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:F8BC-19B8@192.168.2.101:49325;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.10.10.1:5060;branch=z9hG4bK168203A
User-Agent: Cisco-SIPGateway/IOS-15.3.1.T
Max-Forwards: 70
Timestamp: 1415207346
CSeq: 102 BYE
Reason: Q.850;cause=0
P-RTP-Stat: PS=0,OS=0,PR=0,OR=0,PL=0,JI=0,LA=0,DU=0
Content-Length: 0
000201: Nov  5 12:09:06.135: //194/38C81CF58157/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:9085776815@208.93.226.215:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.10.1:5060;branch=z9hG4bK1692321
From: <sip:2016841000@10.10.10.1:5060>;tag=3629BC-13C0
To: "DAVID MARTINEZ" <sip:9085776815@208.93.226.215>;tag=NX71mU55tZNZH
Date: Wed, 05 Nov 2014 17:08:39 GMT
Call-ID: 3fa84e7f-dfb1-1232-769b-f04da23bbb59
Max-Forwards: 70
CSeq: 102 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=1177,OS=188002,PR=1321,OR=206368,PL=0,JI=0,LA=0,DU=26
Content-Length: 0
000202: Nov  5 12:09:06.147: //194/38C81CF58157/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 102 BYE
Timestamp: 1415207346 0.000101
User-Agent: Broadvox Fusion
Content-Length: 0
000203: Nov  5 12:09:06.151: //194/38C81CF58157/SIP/Msg/ccsipDisplayMsg:
Received:
ROUTER-2911#uSIP/2.0 200 OK
CSeq: 102 BYE
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, INFO, UPDATE, REGISTER, REFER, NOTIFY
Supported: timer, path, replaces
Content-Length: 0
000204: Nov  5 12:09:06.859: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 2 BYE
Content-Length: 0
000205: Nov  5 12:09:06.863: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ROUTER-2911#un aSIP/2.0 200 OK
CSeq: 2 BYE
Content-Length: 0
ROUTER-2911#un all
000206: Nov  5 12:09:08.047: //198/422A7502815F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Wed, 05 Nov 2014 17:09:16 GMT
CSeq: 102 BYE
Content-Length: 0
Can you also provide your
Did you capture the full debug? Can you also provide your voip dial-peers configs.
HTH Regards, Yosh
Seemed to have figured it out
Seemed to have figured it out for now at least.. I knew playing with the codecs got it to fully work on the Android. After I mentioned that I believed its a codec issue to the user and explained how it worked with the bandwidth etc. The user mentioned that on the Jabber in there phone they enabled low bandwidth and after a quick google I found this.
Iphone
Low Bandwidth mode supports G.729a only.
The codecs that were enabled with the in/outbound dial-peers were:
voice class codec 1
 id mac 787E.6178.2D4B
 number 1 dn 1
 dtmf-relay rtp-nte
 username Jack password xxxxx
 codec g711ulaw
 no vad
I had the user disable the low bandwidth mode and after I recreated the profile under voice register global and it worked.
My next question is there a policy to grey out all of the configs which will prevent the user from making any changes once the user is Connected via Jabber so this does not happen again?
283
