Jabber/LDAP using iPhone Error
I'm trying to connect an Apple iPhone(OS 6) to Microsoft 2008 Active directory, but I'm getting the below error when I enter the username and password.
  • Credentials required or incorrect search base
When I exported the logs from android, I see that It connects to AD succefully for a second:
-- 2014-01-02 13:08:53.045 DEBUG [3b7f918c] - [UMCAccountViewController _initAccount:<UMCDirectoryAccount>:  X.X.X.X:389  isNewAccount:1
- 2014-01-02 13:10:46.229 DEBUG [82c1000] - -[CSILDAPQueryOperation performOperation]
-- 2014-01-02 13:10:46.233 DEBUG [3b7f918c] - Connected to an ActiveDirectory LDAP server
-- 2014-01-02 13:10:46.233 INFO [3b7f918c] - Naming Context found: DC=example,DC=com
       --[CSILDAPPersonDataSource ldapConnectionQueryDidComplete:]
After that everything goes downhill after that:
-- 2014-01-02 13:10:46.240 DEBUG [3b7f918c] - -[UMCAddressBook dataSourceDidFailConnect:]
-- 2014-01-02 13:10:46.241 INFO [3b7f918c] - [UMCAccountViewController account:didFailVerificationWithError] Error: Credentials required or incorrect search base
-- 2014-01-02 13:10:46.250 DEBUG [3b7f918c] - [UMCDirectoryAccount setConnectionStatus]: Disconnected
-- 2014-01-02 13:10:46.250 DEBUG [3b7f918c] - -[CSILDAPPersonDataSource stopDataSource]
-- 2014-01-02 13:10:46.251 DEBUG [3b7f918c] - -[CSILDAPDirectory unbind]
-- 2014-01-02 13:10:46.252 DEBUG [3b7f918c] - CSILDAPDirectory addOperation: CSILDAPUnbindOperation
-- 2014-01-02 13:10:46.254 DEBUG [3b7f918c] - [UMCAccountManager connectionStatusDidChange]: new otherServices is 2
-- 2014-01-02 13:10:46.254 DEBUG [82c1000] - [CSILDAPUnbindOperation performOperation] Unbinding self.directory (<CSILDAPDirectory: 0x6a509d0>)
I have used the same IP and port for android phones and they connect seemlesly. I have used  port 3268 and 3269 both didnt work. This is my current settings:
Everyone's tags (5)
1 REPLY
Hi Zekeria.
Give a look to this DOC if it can be useful
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080bbcd05.shtml
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
239
