I am able to make the local call in iphone/Android device,when i try to make a call from Window client iam facing issue on only local calls to mobile,,,,but when i tested in deskphone i am able to complete the calls..,can any body suggest me on this
I just had a similar issue, the calls were going out as video, debug the GW and if that's the case, change the config to bearar-cap speech.
java
if this helps, please rate
