Jabber to 9971 CME no video via CUBE
Jason Aarons
Level 6
Level 6
I can make calls Jabber sotphone/Jabber softphone with video fine.
I can make calls Jabber softphone  to same cluster CUCM 9971 with video fine.
When I make a call Jabber Softphone call via CUCM SIP Trunk to CUBE to CME 9.1 15.2 I get no video.  Any ideas?  Is there a setting for RTCP on a sip trunk or dial-peer or somewhere else in CUBE or in CME?  As I saw a similar issue on NetPro resolve that.
CUCM 9.1
CUE IOS 15.1
CME 9.1 / IOS 15.2M5
9971 SIP9.4.1.9
Jabber for Windows 9.7.2
Hello!
Does video work inside CME?
Did you configure 'video codec' inside dial-peer?
Kirill
The cube has media flow-around globally.
Let me trying adding a "video codec h264" on the CME side dial-peer.
Did you resolved this issue? I am having the same problem
