08-30-2014 02:53 PM - edited 03-16-2019 11:57 PM
I need to confirm that only Video calls with jabber can be held only using Jabber for video and if it is a must to have Tele-presence server ?
Ordering Requirements for Jabber Video Enterprise | |
Cisco TelePresence Management Server | CTI-TMS-APL-K9 |
Or video calls can be held using Jabber voice or also jabber for IM or also jabber for windows ? and if so how to start video show while the call is going ?
08-30-2014 03:44 PM
Aside from the very few (and old) jabber versions which were IM only, you can pretty much do video calls with all the new jabber clients, either using CUCM or VCS + tms
08-30-2014 04:27 PM
thanks Jaime for reply
So when jabber voice call another jabber voice. is the video session start automatically ? or I need to trigger it to start the video conversation ? and how ?
08-31-2014 07:32 AM
Two points to clarify:
08-31-2014 11:25 AM
Great Jonathan
the word Jabber is a brand not product is clearing all doubts
Only I tried to create CSF device with cucm 10.5
And tried to register Jabber with the CUCM as softphone without having IM & Presence server by login user name and password
But it fails
So is jabber still require the presence server to register ?
I tried the boot strap install with DEVICE_TYPE=Phone_Mode but not help
Is it doable ?
08-31-2014 11:37 AM
Phone Mode is relatively new and only exists on the Jabber for Windows client thus far. That's the only scenario where the current Cisco Jabber client doesn't require an IM&P server. Remember that the IM&P server software or functionality is free; all you need is the necessary compute power and time to install/configure it.
The only reason they are releasing Phone Mode in the first place is to eventually be able to end of life the IP Communicator client. That's likely a ways out still though considering how many features CIPC has that Jabber still lacks.
Here's the relevant config checklist for phone mode. Make sure you've taken care of each of these steps:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/10_5/CJAB_BK_D6497E98_00_deployment-installation-guide-ciscojabber/CJAB_BK_D6497E98_00_deployment-and-installation-guide-for_chapter_00.html#CJAB_TK_P8CC77D3_00
08-31-2014 11:50 AM
Great
I tried this that is exist in the link you sent
msiexec.exe /i CiscoJabberSetup.msi CLEAR=1 PRODUCT_MODE=Phone_Mode TFTP=1.2.3.4 LANGUAGE=1033 /quiet
But there is no PRODUCT_MODE=Phone_Mode parameter in CUCM 10.5
When I try help, i found parameter called TYPE,
So it failed to get this and failed to register
Only for not mis understanding,, you mean with phone mode is jabber alone as IP communicator and not controlling an IP Phone. right ?
08-31-2014 09:22 PM
That's an install parameter for J4W, not a CUCM parameter, the snip you posted clearly shows that.
You should see that option when you try to log into J4W, if you try to customize the options, a phone only mode should be there.
09-02-2014 02:05 AM
Hi Jaime,
Yes I have tried with J4W but it is didn't recognize it
Now, I need to know when Jabber for voice start supporting video calls
It is on CUCM 10 or before ?
Or it is supported only with J4w ?
Haitham
