Community Member
Java process huge memory usage
Hi everyone...
I have a CCM with Version 6.0.1.2000-3 and platform 7825I3.
Recently (1 week) I have unregistered phones, I check the network (0 problems) and I found a memory problem. My server has 2 gb and I have actually 1.99 Gb of use. In the list of the process, the top process is the Java#1 with 1 gb of memory.
So, any of you could help me in order to give some tips to resolve this. I already attach the image of the list process geerated in the RTMT.
Thanks in advance!!
1 ACCEPTED SOLUTION
Bronze
Re: Java process huge memory usage
Hi Enrique,
glad it helped! our cimserver consumes about 11MB VmRSS and 280MB VmSize after the patch.
i think the java process is actually the tomcat application server for callmanager, since callmanager is a java program.
so don't worry, the VmRSS 230MB and VmSize about 1GB is fine. java does not release the max heap size, hence the java memory usage should be pretty constant.
best regards, Oliver
Community Member
I had a similar issue on our CUCM 6.01 server, to fix this issue, I ensure that all traces levels were set to the default (error) and rebooted the cluster.
Community Member
Actually, I have all the defaults applied to the server, but the behavior appear to be the same, any hint?
Thanks again for your time and support!!
Enrique
Bronze
i think you are facing the bug CSCsl71487 with the snmp memory leak in cimserver. there is a hotfix workaround available you can use with 6.01 which restarts the cimserver every sunday.
otherwise you can update to 6.1.2 ES which has fixed the bug.
hope this helps!
Community Member
Hi!!! Thanks for your support, I'm gonna try the patch first tonigh, and tomorrow I'll reply with the results.
Thanks again!!!
Enrique
Community Member
Can't locate the patch!!! Do you have te exact URL to download it???
Thanks again!!
Enrique
Bronze
Hi Enrique,
according to the bug description the cop file ciscocm.hardware.snmp.sw.memory.leaks.workaround.1.cop.sgn is located in the download section of CUCM. however, i did not found it.
maybe you have to open a tac case for special file access.
because we have faced the same problem, i have attached a copy of cop file to this thread.
Oliver
Community Member
Thanks a lot Oliver, let me try installing this patch, and I'll reply the results.
Enrique
Community Member
Oliver: I install the patch, and actually the memory usage for the cimserver goes down incredible, but I still have the java as the highest mem eater..
I'll restart the server tonight... but maybe you have any other idea about the java process. I attach the process list on the RTMT
Best Regards!!
Enrique
Bronze
Hi Enrique,
Community Member
Actually this problem was resolved, the procedure that Oliver told me, reduces the memory consumption.
In fact, the origin of the problem was an IP duplicated :S
Thanks a lot for your help and time Oliver!!!
281
