JRE on CCM DST
On all the field notices Cisco mentions there is a problem with JRE and DST. It however does not give a workaround for this. Will this effect anything such as CAR. Any ideas.
Jason
1 REPLY
Hall of Fame Super Red
Re: JRE on CCM DST
Hi Jason,
The lateset revision of the DST doc which came out yesterday (March 7,2007) still shows this as an unknown ??
Daylight Saving Time Solution Overview
Depending on the configuration, there are up to five software items which may be required to make a CallManager system Daylight Saving Time compliant.
CallManager Database Table update
Windows 2000 Patch
Phone Loads
Time of Day (TOD) Routing patch:
Important - Workaround required if using TOD routing (patch not yet available). Not implementing this workaround will cause calls to be incorrectly routed during two one-hour shifts in the day (start of workday and end of workday).
JRE patch - patch and workaround still under investigation
From this doc;
Field Notice: FN - 62669 - U.S. Daylight Savings Time Policy Changes Effective March 2007 - for Cisco CallManager
Document ID: 81997
Revised March 7, 2007
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_field_notice09186a00807e02b1.shtml
Sorry, I couldn't be of more help on this, but I have been keeping an eye on the revisions and nothing yet. Lets hope that means that there must be nothing serious.
Take care,
Rob
PS: I will post back if I see anything :)
112
