Keypad Lock of Cisco IP Phones with CME 8.6
Dear All,
Please let me know if the keypad be locked for Cisco IP Phones..I have 7911 7941, 7945 etc ip phones with CME (8.6)? If there is any command on the router (CME 8.6) that we can configure this feature?
Thanks in Advance.
This feature is not avilable.You could use FAC(Forced Authorization Codes) to obtain the security level.
Gnaneswaran.
Hall of Fame Super Gold
Described in administration guide, afterhours call block and PIN.
Blue
You can use it by AXL service configuration and third party application. Un build it is not a feature in ip phones.
http://www.andtek.com/communications-products-lockout.html
Ronak Patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Please refer to the
Please refer to the discussion : https://supportforums.cisco.com/discussion/12058726/keypad-lock-cisco-ip-phone-6941
436
