01-26-2014 03:55 AM - edited 03-16-2019 09:26 PM
Does anybody know why in only one users within a Company (at least that is what Administration VoIP said to me) the keypad in a CUPC has disappeared, presence status is running fine, only falis the keypad, which is lost.
Thanks!
01-26-2014 04:55 AM
Hi Ivan.
On CUCM, check if Primary extension is selected on user configuration page.
Carlo
02-04-2014 01:12 AM
Hi Carlo
Thanks for your quick answer and sorry by my delay in answer you.
After review all into the user , line, CSF and so on, all seems be fine, but still the keypad is lost.
A colleague say me that could be a TFTP issue , or something else but we see the state connected in the CUC.
User says "when i try to talk to other user a windows appears with the error ´Function not available´ "
Any idea where could be the problem??
02-04-2014 02:12 AM
Hi ivan,
Try to logout and login again for that client and check the health status from that CUPC.
Also is it a softphone or deskphone?
Nishant Savalia
