Lab for BACD
twissam
i have set a lab with two routers:
one have VIC2-2FXS (one of them connected to an analogue phone and another connected to the FXO on the second router)
i can call from Router A to Router B IP phone, but i am trying the BACD with no success, ultimitly i want to reach drop through configuration but for now i just want the tcl to work. i beleive i am missing something with the pots!!!
Good day
++++++Sorry the config is below++++++
Router destination (CME)
application
service queue flash:app-b-acd-2.1.2.2.tcl
param queue-len 10
param aa-hunt1 300
param queue-manager-debugs 1
param number-of-hunt-grps 1
service aa flash:app-b-acd-aa-2.1.2.2.tcl
paramspace english index 1
param handoff-string aa
param dial-by-extension-option 5
paramspace english language en
param aa-pilot 101
param max-extension-length 4
paramspace english location flash:
param second-greeting-time 60
param welcome-prompt _bacd_welcome.au
param call-retry-timer 15
param service-name queue
voice-port 0/3/0
dial-peer voice 5000 pots
service aa
incoming called-number .T (or 101 same)
port 0/3/0
Calling Router: Router A
voice-port 0/0/0
FXS where the phone is connected
voice-port 0/0/1
connected to the second router's FXO port 0/3/0
61 Replies 61
This is CSCsd14203. Either configure a workaround as per bug details, or use my patched B-ACD/AA "PL2 branch" that doesn't present the problem, and do few things the standard doesn't:
http://pbevila.fastmail.fm/public/app-b-acd-aa-2.1.2.2-pl2.tcl
Great everything is working now, i will move to configure drop through.
i did solve it before i saw the bug (i will try it now) but what i did is simply in the telephony-service add the B-ACD moh
moh en_bacd_music_on_hold.au
thank a lot
Good day
I am still checking why this is happening:
when i remove the moh music-on-hold.au from telephony-service everything works, i can call the hunt group.
so confusing ;-)
I will let you know
Good day
i am at the step of live setup.
i have tested it and i have the problem of the disconnection.
i am sure that the paramters addressed in the disconnection are right since it is working without the AA, i am not sure if we need to add something specific for the B-ACD:
what is happeninig is when i call in and than hangup from the pstn side, the phone continue on ringing.
Good day
This is supervisory disconnect problem. Learn about it at:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Note, unless you are in NA, where ground start is optionally available, the only thing you can do, is configure tone-based disconnect supervision. But to test that, you need a live pstn line.
The parameters you have now "appears" to be working, but are not because ultimately when you hang up the ip phone, it that makes hang up the fxo as well.
Exactly, i use the last option: (even though i do not use the cptone, but by default is the us i guess)
voice class custom-cptone voice
dualtone busy
frequency 435
cadence 330 330
dualtone ringback
frequency 435
cadence 1180 4520
dualtone reorder
frequency 435
cadence 200 200
dualtone disconnect
frequency 435
cadence 200 200
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone voice
no vad
no comfort-noise
timeouts call-disconnect 5
timeouts wait-release 5
but not ok with the AA
The actual tone can be different from what you configured.
Call in, answer from ip phone, have caller hang-up. Listen to the tone and compare with the tones at:
http://www.3amsystems.com/wireline/tone-search.htm
worst case you will have to record the disconnect tone and do a frequency analysis.
i will check the tone issue, the problem is that the customer is in UAE and i a doing all that remotly, i guess i will open a TAC.
by the way i did used the cool edit earlier and it is confirming the frequency i am using for the disconnect.
in UAE it is 350 for cadence and 400 for the frequency.
Good day
But in the config sent, you have frquency 435 and cadence 200 / 200.
Beside, the PSTN tones database, that is very reliable, indicates frequency 425 and different cadences.
Hi again,
you are right, in fact i have tried a lot of frequencies and this one was the last i tried.
i tried 400, 425 and 435.
Good day
Can you send the disconnect audio file here ?
hi and thanks again for your help, unfortunatly i do not have the sniffing anymore and baiscally i will go with CUE to overcome this problem. when i visit the customer next week maybe i will do another sniffing and send them back over.
good day
here you go, i just got the sniffing.
192.168.1.35 (IP phone) and the CME 192.168.50.1 (TFTP)
i did not check it this time but last time it was 400 Hz and 350 for the cadence
Thanks in advance
I'm stuck home with a cold and can't access necessary software. Will givie it a loos wehn possible.
"Salemtak" = I hope you will get well
