Large number of Speed Dials
sandonen
I'm migrating a site that has over 150 speed dials configured. Does anyone have any suggestions? I don't believe I'm going to be able to due this using speed dials since the limit appears to be 99. I was thinking that translation patterns maybe my only choice. I'm currently running CCM 4.2. Tx
5 Replies 5
Chris Deren
Are these system speed dials that everyone is using? If so then TPs are you best bet, unfortunately there is no Bulk way of importing TPs until CM 6.0. Your best way if you dont want to do manual TPs, is to create dummy cti ports or cti route points with the forwardAll destination configured.
HTH,
Chris
The Speed dials are for everyone.
I was afraid that this might be the case.
Thanks for the info.
twissam
how do you share the 150 speed dial?
what is the step by step setup.
Good day
create 150 translation patterns and put them on a partition that is cointained by everyone's Calling Search Space. In this way you can "share" them.
HTH,
Simone
make sense, i though you can put them in the directory services.
thanks.
Good day
