Layer 2 problem with E1 Controller
I have Cisco 3800 router with 2 port E1 controller card ,problem i have is that the 1 port on the controller works fine ,but the other port keeps giving me a TEI_ASSIGNED status when i do a sh isdn stat ,after running Q921 debugs i can see that my router is not responding to SABME messages from the Telco ,any idea what the problem might be ?
Silver
Re: Layer 2 problem with E1 Controller
Have you checked the line type -Qsig, DMS etc, CRC4 on/off, Clocking etc. What about the number of channels, . Can you connect the "good circuit" to the faulty port ?
Here are the configs from the router ,also when i connect the good circuit to the faulty port the same situation occurs
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
network-clock-select 2 E1 0/1/1
controller E1 0/1/0
pri-group timeslots 1-31 service mgcp
controller E1 0/1/1
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/1/1:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn sending-complete
no cdp enable
Hall of Fame Super Gold
Begin posting here output of "show controllers E1".
Here are the outputs from sh controllers e1 and sh isdn status ,the 0/1/1 is the faulty port
XXXX#sh controllers e1
E1 0/1/0 is up.
Applique type is Channelized E1 - balanced
Cablelength is Unknown
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20071011, FPGA: 13, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (280 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
16391 Line Code Violations, 16 Path Code Violations,
0 Slip Secs, 1 Fr Loss Secs, 2 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 2 Severely Err Secs, 8 Unavail Secs
E1 0/1/1 is up.
No alarms detected.
Data in current interval (282 seconds elapsed):
2138015 Line Code Violations, 49 Path Code Violations,
83 Slip Secs, 4 Fr Loss Secs, 8 Line Err Secs, 0 Degraded Mins,
81 Errored Secs, 0 Bursty Err Secs, 7 Severely Err Secs, 647 Unavail Secs
XXXXX#sh isdn stat
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/1/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 25
%Q.931 is backhauled to ME 0x0700 on DSL 1. Layer 3 output may not apply
ISDN Serial0/1/1:15 interface
dsl 1, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
Active dsl 1 CCBs = 0
Number of L2 Discards = 0, L2 Session ID = 3
Total Allocated ISDN CCBs = 0
Both ports are experiencing slip errors.
configure:
network-clock-participate wic 0
network-clock-select 1 e1 0/0/0
network-clock-select 2 e1 0/0/1
controller e1 0/0/0
clock source line primary
And check if any improvement.
Also try swapping circuites to interface, see if problem stays with port or circuit.
I have configured the clock source line primary command under the controller ,but still no change. I have also tried swapping the circuits ,the problem stays with the port.
Oops ,i found the problem guys ,sorry it was my own stupidity ,i had forgotten to configure the port in CUCM ,so it had a blank config in CUCM.
1124
