LDAP Directory error in CUCM 8.5.1 SU1
Hi All,
I am getting error " Error while connecting to ldap://xxx.xxx.xxx.xxx:389, null. I came to know about this error when i got a complaint from end users that they are not able to login to ccmuser web page. endusers are active in status and full sync is also working fine. Hence need your inputs to resolve this issue.
Sankar.
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Make sure the LDAP server is still online, and ensure the LDAP distinguished user has not been moved to different OU or deleted.
HTH,
Chris
VIP Super Bronze
Looks like CUCM has lost connection to ldap. You should investigate this. Check the connectivity between your CUCM and LDAP server..Use wireshark or look at cucm traces...
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
HTH,
Chris
Hi Chris,
The LDAP distinguished user has not been moved to different OU. I have asked the AD team to revert back and it got resolved. Thank you Very much.
Sankar.
228
