05-09-2012 09:37 AM - edited 03-16-2019 11:04 AM
I have multiple OU's under the same parent OU. I understand child containers are not searched down. I have 5 search bases, and need to add another OU. The Number of search bases in CM7.1.5 is limited to 5. Has this been increased in any newer versions? Or is there a way to search more than 5 OU's ?
Solved! Go to Solution.
05-09-2012 10:28 AM
"I understand child containers are not searched down."
That's wrong, unless you're talking about child domains.
To import the data into the Unified CM database, the system performs a bind to the LDAP directory using the account specified in the configuration as the LDAP Manager Distinguished Name, and reading of the database is done with this account. The account must be available in the LDAP directory for Unified CM to log in, and Cisco recommends that you create a specific account with permissions to allow it to read all user objects within the sub-tree that was specified by the user search base.
It is possible to control the import of accounts through use of permissions of the LDAP Manager Distinguished Name account. In this example, if that account is restricted to have read access to ou=Eng but not to ou=Mktg, then only the accounts located under Eng will be imported.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/directry.html#wp1045218
And no, the number of ldap syncs you can configure hasn't changed at all.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-09-2012 06:04 PM
Yes, that's correct and what we have always done to overcome the 5 sync agreements limit.
java
05-09-2012 10:28 AM
java
05-09-2012 01:10 PM
thanks for the quick reply. I have exactly the situation depicted in the document, figure 17-6. I have 5 different search bases, all at different OU's under the same root. I understand from reading that I could use a search base at the root level, and use permissions to control imported users.
" In this example, a single synchronization agreement could have been used to specify the root of the domain,"
Am I thinking this right?
05-09-2012 06:04 PM
java
05-10-2012 04:37 AM
Yes, this is what I did, and indeed it works as expected. Thanks again for your fast response and help
