06-01-2012 01:00 PM - edited 03-16-2019 11:27 AM
We are getting this error when trying to sync.
2012-06-01 13:22:19,539 ERROR [DSLDAPSyncImpl(72515187-27b0-dc9e-01e8-5835e5f4c0d2)] ldapplugable.DSLDAPSyncImpl (DSLDAPSyncImpl.java:608) - LDAPSync(72515187-27b0-dc9e-01e8-5835e5f4c0d2)[Run] javax.naming.AuthenticationException: [LDAP: error code 49 - 8009030C: LdapErr: DSID-0C0903A9, comment: AcceptSecurityContext error, data 532, v1db1
I know the creds are good.
Any assistance is appreciated.
Thanks in advance.
Mike
Solved! Go to Solution.
06-01-2012 01:35 PM
HI Mike,
Can you check if the user's password has not expired? If that's the case change it otherwise try to change the admin account on AD (you can delete it and recreate it).
Tere.
If you find this post helpful, please rate!
06-01-2012 01:35 PM
HI Mike,
Tere.
