LDAP sync problem
I've created user on windows 2008 active directory and I try to sync it to cucm 8.6. When I click on (perform sync process) it change to (Cancel sync process), so I waited but (Cancel sync process) does not change so I've refresh it and still same result. When I try to User Management--End User it does not show the user that I have create. My authenication is in the correct formate. How long show I wait for (Cancel sync process) before I can access Management-End User?
Everyone's tags (2)
1 REPLY
LDAP sync problem
How long are you giving it before cancelling and how many users are you syncing??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
241
