Community Member
LDAP Synch
CUCM 6.1 I have setup ldap integration. It seems to have authenticated o.k but it has been trying to synch for 24 hours. A sit is only a lab I only have 10 users. I have tried recreating but still no luck.
Re: LDAP Synch
are you sure you're pointing to the right OU where users are and that the account used for the integration has read/write privileges over that OU?
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Re: LDAP Synch
Hi Java,
I have cn=Users, dc=Lincroft, dc=com in the user search base. I use the admin account for the Ad server.
148
