LDAP User Privileges
Dears,
wanna do integration CUCM 9.1 with Active Directory and what i know that the user should have "Read" Only privileges to do the integration
BUT:
1- I tried to do it with user has only Read privilges i got error login failure to ldap
2- I change the user privilege to be Admin then i could integrate with call manager
CUCM 9,1 Administration Documents Says:
LDAP Manager Distinguished Name
Enter the user ID (up to 128 characters) of the LDAP Manager, who is an administrative user that has access rights to the LDAP directory in question.
CUCM 9.1 SRND Says (Page 809):
Design Considerations for LDAP Synchronization
Observe the following design and implementation best practices when deploying LDAP synchronization
with Cisco Unified CM:
• Use a specific account within the corporate directory to allow the Unified CM synchronization
agreement to connect and authenticate to it. Cisco recommends that you use an account dedicated
to Unified CM, with minimum permissions set to "read" all user objects within the desired search
base and with a password set never to expire. The password for this account in the directory must
be kept in synchronization with the password configuration of the account in Unified CM. If the
service account password changes in the directory, be sure to update the account configuration in
Unified CM.
What exactly the right privileges for the user ??
Everyone's tags (2)
Hall of Fame Super Silver
Re: LDAP User Privileges
Read only is sufficient, you need to ensure the user is on OU that is part of your search base.
Chris
Thanks Chris for your reply, as i mentioned i just change the user privilege to Admin then it could be accepted to do the integration before that it was giving failure to login ldap
Can you provide the distinguished user string and the search base string? Perhaps the user is outside of the search base hence requires admin rights to read it.
Chris
345
