Silver
ldap users import with access group
I have callmanager 10.5 with LDAP. I want to import users and assign thse users to an access controll group (like ccm enduser etc)
I configure, I import the users, but they are not member of an access controll group and I have to do it still manual.
Not so much work, but why doesn't it work?
Any one else seen this?
JH
Did you add the Group
Did you add the Group information to the System > Ldap directory settings?  In CUCM under the LDAP Directory you're sync'ing with you want to add the Standard CCM End Users to the "group information" for that directory before you sync.
If you sync first, then add the groups it it will only apply the groups to newly created users.
Silver
OK, might have done something
OK, might have done something wrong.
After I am sure the LDAP config is correct, I created a new user in AD, and this new user gets the access group rights.
My mistake.
Thanks!
33
