Community Member
Least Cost Routing for long distance calls
CCM 4.1 MGCP GWs.
I'd like to apply LCR in our environment. I've seen some helpful posts but I am still missing something and feel stuck.
I have a voice gateway (GW_A) in area code 336 and a GW_B in are code 803.
I want to send calls made from 336 to 803 through GW_B. Additionally, there are areas within 803 where calls are treated as local toll (or local long distance), where you would have to dial long distance from GW_B (1803xxxxxxx).
Any ideas of how to accomplish this?
I think I know how to send the call to the gateway (Through Route Patterns and, Roulte Filters, and\or Route List?), but I am not sure of how to treat the digits so that the call gets handled by the next GW appropriately.
MGCP GWs full converged VoIP over MPLS.
We currently already have a bypass toll code for each office like this:
639.@ sends it to GW_B and uses route filter 7 digits local. This route pattern is in the active partition for all my lines. Discard Digits PreDot.
GOing to CUCM 6.X very soon.
Any ideas would be greatly appreciated.
Bronze
Re: Least Cost Routing for long distance calls
It is a big topic to explain through this media, but I can tell you the basics.
You need a route list per route, and then use the dot to remove the area code when the call goes to the first route group (gateway), and prefix 1+area code when the call fails over to the second route group.
HTH, Avner.
Community Member
That's what I am trying to figure out. But I don't know what I am missing.
Community Member
I have done something similar before using route filters because some office codes within the area code are LD and some are not.
So you would have multiple 9.@ route pattern with multiple route filters. It is a lot of work, but that is the best way to do it. You just need to read up on route filters and wildcards. Keep in mind that there is a limitation to the number of rules in a route filter so it is conceivable that you could have multiple router filters per area code all containing different office codes.
Community Member
Thank you huntley. I thought about that too, but it may be a lot of work.
On the other option, I can send the call to the remote gateway using RL and discard digits. No problem there. The problem is I don't know how to make it fail over if the office code is LD for the remote gateway.
Say I am in Charlotte, I dial 91803407XXXX to Columbia. The call is sent as 407XXXX to the Columbia gateway and connects no problem.
Now I am in Charlotte and dial 91803436XXXX. This an intra-lata LD call from Columbia to Sumter. The call still goes out as 436XXXX. I need to put the 1803 back so it can complete.
I can't figure it out.
Community Member
It is a hard subject to explain in short form, but essentially as mentioned by the poster above, you would need another route list that does a called party transformation and does a prefix digits 1803. So if you had two route patterns you would need two route lists.
One would just do a pre dot or whatever standard issue think. The other would do the prefix digits.
284
