Legacy Modem Connection over VWIC-1MFT-E1
Hi All,
I have a setup that I need to verify before I get in any trouble.
I have a 2811 router that is acting as a voice gateway on a network that has CCM 6.x. The router has a VWIC-1MFT-E1 card that terminates a digital E1/PRI trunk carrying 30 phone lines with a hunt group number.
The new requirement is a legacy machine in my environment that requires remote access over legacy analog telephone line. What I'm thinking of is adding a VIC-2FXS and connecting this modem directly to this FXS VIC. However I'm not quite sure if:
  1. FXS VICs support modem relay/pass-through?
  2. If it does, then what is the most suitable way to forward a call arriving on the digital trunk calling a hunt group number to a physical FXS port? Can I assign a DID number which can be auto-forwarded to the FXS port? Use the help of an operator to manually transfer the call?
I checked the usage of an ATA186 but apparently they don't support modem relay/pass-through !
I've attached a mini diagram to make it clear.
Help !!!
Salem.
Green
Salem,
1) Yes you can use the vic-2fxs
2) You can use thre dial peers to route the call to
the FXS/Modem
Lets say you have a spare DID E.G. 654329
This is called inbound via your E1
Build a dial peer something like this :-
dial-peer voice 1009 pots
desc *** MODEM PEER*
destination-patttern 654329
port 1/0/0
voice-port 1/0/0
desc *** MODEM PORT ***
cptone YOUR COUNTRY
Your call will be using POTS to POTS
so there is no issue with fax-modem pasthru or relay
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Thanks acampbell ... most appreciated.
Cheers,
Salem.
620
