Community Member
licence call manager 6.1 cluster
hi,
i need to install 2 mcs 7816 in cluster.
the customer have pourchased 2 Lic-CM6.1-7816. and one LIC-CM-DL-100
i know that the publisher acts as manager licence,
shoud i use 2 Lic-CM6.1-7816 with to address MAC or just one licence with mac's publisher.
shoud i need one LIC-CM-DL-100 that covers my phones or ech server need its LIC-CM-DL-100.
thanks
1 ACCEPTED SOLUTION
Re: licence call manager 6.1 cluster
If it's new, you should have a PAK key. Enter in the PAK key and it should should show you (2) nodes for CUCM 7916 and the 100 DLUs. You can check these out all at one time. If you PAK keys for example:
(1) Node
(1) Node
(1) DLU 100
Check each out and when then ask for the MAC, put in NIC1 of the publisher.
When the files are emailed, use the CUCM admin page to upload the files and it should work then.
Everything should be licensed to the NIC1 on the Publisher. When you add the Subscriber, it will get the license information from the Publisher.
Community Member
that is mean i generate :
- 2 licence files for 2 nodes where i use the mac of the first node.
- one licence file for phones
it's right, please confirm
thanks
(1) Node
(1) Node
(1) DLU 100
Community Member
thank you for your assistance
185
