Bronze
Licence Retrieval on CUCM6
Guys,
Anyone know how to retrieve the licence from CUCM6. In version 5 you can just view the licence and you have the option to save it. In version 6 the licence is displayed in the GUI.
As it is obviously stored somewhere is there a way with the OS to pull it down. I ask as the original installing engineer has left the vendor we used. So want to try to pull them down before we go back to Cisco licencing .
Paul
Hall of Fame Super Red
Re: Licence Retrieval on CUCM6
Hey Paul,
Hope all is well my friend! I have not tried this...but from the cli I would try;
file list
file view
file get
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_1/cucm-rel_note-611b.html#wp254330
Hope this helps!
Rob
Bronze
Rob,
You dont know what durectory they will be in tried the wildcard but to no avail
Paul
it's not in a directory you can see without root access, simply copy the file contents into a wordpad
java
if this helps, please rate
java
www.cisco.com/go/pdi
Bronze
Ok will do but thought doing this may be an issue with CRC checks etc.
Many Thanks
PAul
127
