License File when upgrading to Callmanager 5.0
I am upgrading to Callmanager 5.0 from Callmanager 3.3(5) - and then to Callmanager 4.1
I have run DMA 5.0(2a), and have succesfully migrated the configuration and so now have a working 5.0 server (almost).
I cannot see how or where the license file gets created, nor can I see any meaningful documentation which describes the exact process on CCO.
Anyone out there done this and can point me in the right direction?
Cheers
Hall of Fame Super Red
Re: License File when upgrading to Callmanager 5.0
Hi Brian,
Here is some info to help get you started;
Migrating from Cisco CallManager 4.0(x) to 5.0(x)
When you migrate from Cisco CallManager version 4.0(x) to 5.0(x), the licenses that are required for existing phones and existing Cisco CallManager nodes is calculated and an intermediate file (XML file) that contains these license counts will be generated during the Cisco CallManager migration process. These licenses are given free of cost because you are already using these phones for Cisco CallManager version 4.x. If you are provisioning new phones and nodes after migrating to Cisco CallManager 5.0(x), you need to paste the intermediate license file in the License Registration window on CCO.
Use the following procedure to register existing licenses and request for new licenses.
Step 1 In Cisco CallManager Administration, choose System > Licensing > License File Upload.
The License File Upload window displays.
Step 2 Click View File. A pop-up window displays that has the license information for existing phones and nodes. Copy this information. To copy the contents on this windrow, you can use Ctrl-A (Select All) and Ctrl-C (Copy).
Step 3 On the License Registration window of CCO website, in the text box provided, paste the file contents using Ctrl-V.
Step 4 You must enter the MAC address of the Cisco CallManager server that you are requesting the licenses for, and a valid E-mail Id.
Step 5 To obtain the actual license file, click Submit. A license file is generated.
Step 6 You must upload the license file to the server with the matching MAC address that you provided in Step 4. See the "Uploading a License file" section in the Cisco CallManager Administration Guide. This node takes on the functionality of the license manager.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a0080531ebb.html#wp1100548
Take care!
Rob
OK
I am still not clear which .xml file I should be looking at. Can you tell me what filename is created as I can see dozens of xml files created in the DMA folders......
TIA
Brian
126
