License Files
After I uploaded the license files for CCM 6.1 I get the following message "Cisco Unified Communications Manager service should be restarted after uploading software version license file"
where is this service located at? and what is it called. I have looked under the services but do not see anything with this listing.
thank you
1 ACCEPTED SOLUTION
Silver
Re: License Files
- Go to the CCMService page go to Tools >> Control Center - Feature Services.
- Select the Publisher CallManager server from the drop down box and click go.
- Under CM Services, select the "Cisco CallManager" service and click on restart.
That is the service that should be restarted.
Re: License Files
You should go to Cisco Callmanager Servicability (top right hand corner drop down box) and go to Control center to restart the service. Remember there are Feature services and NEtwork services. Use Feature services.
Re: License Files
thank you sir, but I do not see a service called Cisco Unified Communications Manager service. Is it called something else?
Re: License Files
Yeah it may be called Cisco Callmanager service.
Re: License Files
thanks again, the closest one I can see is Cisco CallManager Serviceability, but its under Network Services. Not sure if thats the right one.
Silver
Re: License Files
Silver
Re: License Files
FYI: If the service is not listed under Feature Service is because it is not active, go to Tools >> Service Activation and make sure that the "Cisco CallManager" service has been activated; otherwise, click on "Check All Services" and then Save.
After doing that, the service should be displayed under "Feature Services".
Hope this helps!
Re: License Files
thank you sir, your instructions were very easy to follow.
Points for you both!
thanks,
Mike
Silver
Re: License Files
Thanks! Any time!
330
