license issues after changing hostname and domain andCUCM 7.1.3?
If I change the hostname and the domain of an CUCM Business Edition 7.1.3, I have to update the installed license files?
At CUCM 8 there are many changes in licensing and there is a customer impact by changing some parameters (http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_0_2/install/cmins802.html#wp584709).
Is there any similar for the 7.1.3?
Hall of Fame Super Red
Re: license issues after changing hostname and domain andCUCM 7.
Hi SA,
You should be fine
The new Licensing model only applies to new 8.0 builds on VMWare;
Customer Impact from New Licensing Procedures
Cisco Unified Communications Manager on VMware on Cisco UCS B-Series Blade Servers uses a different licensing model than Cisco Unified Communications Manager on an MCS server. The MAC address of the NIC card is no longer used to associate the license to the server.
Instead, the license gets associated to a license MAC, which is a 12 digit HEX value created by hashing the following parameters that you configure on the server:
Time zone
NTP server 1 (or "none")
NIC speed (or "auto")
Hostname
IP Address (or "dhcp")
IP Mask (or "dhcp")
Gateway Address (or "dhcp")
Primary DNS (or "dhcp")
SMTP server (or "none")
Certificate Information (Organization, Unit, Location, State, Country)
This hash of these fields is called the LICENSE MAC
Note : Once there is a change in any of the parameters that creates the License MAC, it will
give you 30 day grace period to generate a new license file for the CM based on new license
MAC.
Cheers!
Rob
If I start to change the hostname at the 7.1.3 I've got the message:
"WARNING: Changing this setting will invaidate software license on this server. The license will have to be re-hosted."
What this mean? What to do? Can I ignore this?
Hi SA,
Is this a VMWare build or a more standard MCS server? The 7.1(3) license
is based solely on the MCS server MAC so I can't see why this warning
would be applicable.
Cheers!
Rob
521
