Silver
license question on 6.x
I`ve just installed 6.0 CUCM and have 50 license for handsets and a node license being shown , I`ve created 3 x devices and the number of units have decreased in the reporter but the phones are not registered. Are these licenses real or do I need to download a license files from Cisco. I have a PAK code for 100x DLU`s not yet added as I`m thinking to installing this on another CUCM as they are both part of a lab
thanks
Bronze
Re: license question on 6.x
Hi, you should not have this problem to register the devices, check if the CCM service , TFTP service and the necessary services are running in the your server.
David
Silver
The servics are running but the phones just shows registering. So teh 50 licenses on the CUCM shoud work ok ? there is nothing else I need?, I don`t have to go to cisc.com/licensing etc? Also how do I obtain the MAC address from the Pub
Bronze
Hi again, check the switch configuration if you are using vlans, the IP/default gateway/option 150 (TFTP) if you are using DHCP.
Hope this help
David
Silver
it is sorted now, the lab switch I was using was to set up for inter vlan routing though I asked for it- thanks
110
