Community Member
licenses issue with publisher and subscriber
Hi everybody.
I have upgraded my ccm 4.2 publisher and subscriber to cucm 6.1 and after that i send the file .lic generated by dma to cisco licencing, I also register the two PAK of number to receive the the software licences. with the publisher mac address
I have uploaded to the publisher the
upgraded licenses
the new licences i purchased from cisco
the two licences i have received from cisco with the PAK number software claim
after that when i go to look for licence report in ccm node licenses i see unit authorized 4 unit used 2.
why do i have 4 unit authorized and 2 used, as I know i shoould have 2 autorized two used?
and the publisher is fonctionning correctly but when the ip phone register whith th subscriber there is many issues.
Please help.
1 REPLY
Re: licenses issue with publisher and subscriber
You probably received extra licenses somewhere in the way, look at the lic files for that matter.
You can see how many node licenses are included on each .lic file.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
165
