07-12-2012 06:11 AM - edited 03-16-2019 12:10 PM
We are suggesting IP Telephony Solution for a client who has 1157 users.
Cisco 9971 IP Phones--- 40
Cisco 7965 IP Phones--- 117
Cisco 7911G IP Phones---1000
So kindly let me know what all licenses should be given to get the phones up and running.
CUCM 8.6
Server: MCS 7835 or UCS C200 M2
Awaiting for a early response!!
Thanks & Regards,
Eng Shameem Syed
Solved! Go to Solution.
07-12-2012 07:18 AM
CUCM 8.6 is under UCL licensing. Those phones mentioned above are Enhanced, so you need to purchase 1157 UCL Enhanced licenses.
Hope to help, please remember to rate helpful posts.
Kind regards,
- Adrian.
07-12-2012 10:34 AM
Just use the UCL part numbers. You don't have to use DLU part numbers anymore.
Good luck!.
- Adrian.
07-12-2012 06:43 AM
For the phones
9971 consumes 4 DLU per phone so 40*4=160
7965 consumes 4 DLU per phone so 117*4 = 468
7911 consumes 3 DLU per phone so 1000* 3 = 3000
Total DLU (Device License Units) = 3628 take a 10% ovehead so approx 4000 DLU's
I would recommend 3 node licenses for a 3 server configuration Pub and 2 subc and you would need a SW feature license for the number of nodes where CCM service would be activated.
Hope this helps
Niket
Kindly rate useful posts!!!
07-12-2012 07:18 AM
Kind regards,
- Adrian.
07-12-2012 10:17 AM
Hi Adrian,
Thanks for the information..
So "1157" of "LIC-CUCM-USR-B" are enough or I should also go for device licences. If yes then kindly let me the part numbers of Device Licences.
Appreciate your help & Support..
Thank you,
Shameem Syed
07-12-2012 10:34 AM
Good luck!.
- Adrian.
07-12-2012 10:45 AM
Thanks Adian
03-18-2020 09:59 AM
