Licensing Question
Hi Guys,
Can someone tell me what is the below used for. Have searched the forums/internet and found nothing on this.
Please help. The customer wants a PAK for this but there is none.
PUBLIC-IP-DEV-UWL Public Space non-app phone add-on for UWL - 26 nos
Varadarajan.R
1 ACCEPTED SOLUTION
In older versions of CUCM
In older versions of CUCM there was the concept of public space licenses, so a phone that was in a lobby for instance and not assigned to a user so yes equivalent to no user\common space.
Essential wont work as its only for the Analogue phones but basic would cover it.
This is a single phone
This is a single phone license for a public space device but its EOL.
Think replacement would be lowest tier license that meets the requirements
Thanks for the reply. What do
Thanks for the reply. What do you mean by Public Space device ? Is it the equivalent to "no user" attached to the phone ? So this can be replaced by a essential or a basic license ?
Thanks a lot. One last thing,
Thanks a lot. One last thing, do we get a PAK for this ?
VIP Purple
Hi Rajan,I think you won't be
Hi Rajan,
I think you won't be getting any PAK for the same since Essential license is RTU for Public Space Devices.
regds,
aman
121
