Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
limit access to ccmadmin URL
Hello!
Is it possible to limit access to the http://<server>/ccmadmin URL to a specif ip address range?
Michael
Re: limit access to ccmadmin URL
yes, but it has nothing to do with CUCM since you need to create ACLs on the router or L3 switch to achieve this
CUCM has no way to do this by itself
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hello java,
an ACL will not help because everyone should be able to access the ccmuser page but not the ccmadmin page. so I cannot block port 80.
Michael
just don't give the users access to ccmadmin by not giving them privileges to log in
just give them access to ccmuser
if they can get to the page but not login there is nothing to worry about, if this is no good then do ACLs using the URLs and not per port or protocol
java
java
144
