Limit bandwidth on cisco 2960 switch
Hi All,
I wish to limit traffic on switch port for my various customers ranging from 10mbps, 256 and 512kbps respectively
Which suitable configuration is appropriate for this
1 REPLY
Green
On a 2960 you can not limit the ingress traffic.
Refer to the config guides
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/scg_2960.html
However you can limit the egress.
Example
mls qos
interface fas 0/1
srr-queue bandwidth limit 10
This will limit the egress - outbound traffic to 10% of the ports speed.
So if your port is running at 100Mbps then it would only output at 10Mbps
Alex
Regards, Alex. Please rate useful posts.
1421
