Community Member
Limit call duration
I have CUCM 6.1.2. How can I limit call duration for a particular user ?
Bronze
Re: Limit call duration
Hi, I think that CUCM doesn't have this kind of feature, for call control only FAC, CMC or CSS.
Maybe you can use a third-party solution.
Best regards
David
there is a parameter, but affects ALL CALLS.
no way to limit only for particular user(s)
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Ok, I will try to write tcl script on the voice gw to PSTN.
Community Member
I also had similar problems but have not been able to solve it
Hall of Fame Super Gold
One reason it is difficult to do is that a proper solution does not only limit a single call, but accounts for total time, warns when time is about to expire, send reports to administrators, etc.
After confronted with the cost of that you will find that most customers are not interested anymore.
378
