06-19-2009 06:41 AM - edited 03-15-2019 06:37 PM
My boss to aks for to limit calls to 3 minutes, is possible to do this?, I have call manager version 4.1
06-19-2009 06:55 AM
Yes, there is a maximum duration CCM parameter.
But it affects ALL calls. There is no way to just apply the setting to certain phones, ANY call made from CCM will be affected.
java
if this helps, please rate
06-19-2009 07:08 AM
How i can see maximum duration CCM parameter at call manager?
06-19-2009 07:11 AM
Go to CUCM service parameters and change:
maximum call duration
java
06-19-2009 07:44 AM
thanks
Is posibble to do any other thing for to make that?
06-19-2009 07:54 AM
You can do a TCL script and run it on the Cisco Voice Gateway.
Best regards,
- Adrián.
06-19-2009 11:17 AM
How i can do that?
06-19-2009 11:51 AM
You need to pay someone, eg myself, to write the script. Or learn TCL/IVR yourself.
