limit calls to 3 minutes at call manager
pesanchez2002
My boss to aks for to limit calls to 3 minutes, is possible to do this?, I have call manager version 4.1
7 Replies 7
Jaime Valencia
Yes, there is a maximum duration CCM parameter.
But it affects ALL calls. There is no way to just apply the setting to certain phones, ANY call made from CCM will be affected.
java
if this helps, please rate
java
How i can see maximum duration CCM parameter at call manager?
Go to CUCM service parameters and change:
maximum call duration
java
java
thanks
Is posibble to do any other thing for to make that?
You can do a TCL script and run it on the Cisco Voice Gateway.
Best regards,
- Adrián.
How i can do that?
You need to pay someone, eg myself, to write the script. Or learn TCL/IVR yourself.
