limit calls to 3 minutes at call manager
My boss to aks for to limit calls to 3 minutes, is possible to do this?, I have call manager version 4.1
Re: limit calls to 3 minutes at call manager
Yes, there is a maximum duration CCM parameter.
But it affects ALL calls. There is no way to just apply the setting to certain phones, ANY call made from CCM will be affected.
java
if this helps, please rate
java
www.cisco.com/go/pdi
How i can see maximum duration CCM parameter at call manager?
Go to CUCM service parameters and change:
maximum call duration
java
java
thanks
Is posibble to do any other thing for to make that?
You can do a TCL script and run it on the Cisco Voice Gateway.
Best regards,
- Adrián.
How i can do that?
Hall of Fame Super Gold
You need to pay someone, eg myself, to write the script. Or learn TCL/IVR yourself.
516
