Limit hours utilization by Directory Number
Hi Guys,
My Customer have the CallManager 5.1.3 and would like know if is possible to limit hours the utilization directory number. I Verified that possible create the Time scheduled as form to limit, but, this feature limit the period and not  hours quantity. Anobody have idea?
Wilson
1 ACCEPTED SOLUTION
Re: Limit hours utilization by Directory Number
CUCM has no method to do this, you would need to write down a custom TCL script which connect to some sort of info repository to update the info of how many minutes have been used vs how many are available and then allow/deny the call.
This also would need you to use H323.
I believe there might be a 3rd party app for this but I'm not sure.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Hi Javalenc,
Thank You for answer.
Wilson
142
