Limit Unity mailbox sizes
If you integrate unity with your exchange 2003 datastore, is it still possible to impose voicemail size limits? For example can I limit a user to X minutes of voicemail, or X megabytes? Or is it all controlled by exchange and the size of their user mailbox?
Hall of Fame Super Red
Re: Limit Unity mailbox sizes
Hi Shane,
Unity uses the mailbox size limits set in Exchange.
Here is an example for Exchange 2000
Understanding How Exchange 2000 Storage Limits Work with Cisco Unity
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_white_paper09186a00800faf0f.shtml
Hope this helps!
Rob
Hall of Fame Super Silver
The mailbox size limit is controlled by Exchange, message duration limit is controlled by Unity. You can also install Message Store Manager to manage retention policy:
http://www.ciscounitytools.com/App_MSM.htm
HTH,
Chris
Thanks Chris & Rob,
I was hoping I could enforce two policies....
-Limit the time a voicemail can be kept (90 days)
-Limit the total storage voicemails can use (50MB or whatever).
I wanted both those policies to be independant of my exchange user mailboxes (because we dont have retention policies for email, and our mailbox sizes are very large).
Sounds like MSM might help, I'll do some reading. Any other options? I assume if I kept it with Unity local storage (no exchange integration) then I can enable those limits?
use Message Store Manager
use Exchange quota settings
Chris
"-Limit the total storage voicemails can use (50MB or whatever).
use Exchange quota settings "
Thanks for the reply.
Would it be possible to have a quota that affects voicemails but not e-mails? I'm not that familar with Exchange.
Nope, the quota is applied to mailbox and it's not aware of the mailbox content. You would need to make seperate mailboxes for email from voicemail, but that would not make it voicemail only deployment and not unified.
Chris
Can't find message store manager in unity version 5. Any suggestions?
Hi Hann,
You can download the tool here :)
Hope this helps!
Rob
in the tutorials, it mention that, it requires exchange 2000 or 5.5 What if I'm running exchange2003? Will it still work?
Hi Hann,
From the MSM Help (in the link I sent :)
Requirements/Special Notes
Requires Unity 3.1.0(1) or greater, running in a Microsoft Exchange 2000, Microsoft Exchange 2003, or Microsoft Exchange 5.5 environment.
The user account running MSM must be a local administrator on the Cisco Unity server.
The user account running MSM must be a Full Exchange Administrator for Microsoft Exchange 2000, Microsoft Exchange 2003, or and Administrator for Microsoft Exchange 5.5.
The user account running MSM must have Send-As and Receive-As rights on each Exchange 2000 and Exchange 2003 mail store the Message Store Manager is expected to act on. See Checking Mailstore Access.
Currently VM Mailbox Rule scripts are supported on Microsoft Exchange 2000 and Microsoft Exchange 2003.
Hope this helps!
Rob
Thanks rob! the tutorial wasn't updated.
Hi Hann,
No worries my friend! There is alot of documentation here that is tough to update. I've always felt the docs and Tools for Unity and Unity Connection are some of the best on CCO.
Cheers!
Rob
240
