Limit user options https://CCM4.2/ccmuser/logon.asp
Hi to all,
We have a cluster CCM 4.2(1), and I would like to know if there is a way that limit the user options, I mean
If a user goes to https://192.168.63.21/ccmuser/logon.asp , don´t want him the option of install plugins or complemets for example.
Best regards,
Alberto
1 ACCEPTED SOLUTION
Bronze
Re: Limit user options https://CCM4.2/ccmuser/logon.asp
If you got to system - enterprise service parameters , then look for CCMuser parameters (its thte third section down).
You can then select what options you want to appear on the menu etc.
Mark
Please rate useful posts
Bronze
Mark
Thanks a lot
569
