Limitation when used "Primary Phone"?
What are the limitations when using the "Primary Phone" function in the CUCM 8.6.
I use a "Jabber Android" client, I know that it allows to use 1 license instead of 4.
But there you it the limitation of use?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
There are no limitations.
Chris
Chris
Thanks Chris,
You're welcome.
HTH, please rate all useful posts!
Chris
187
