limited setting display
alex goshtaei
Hi All,
I am using CUCM 7.0. in the IP phone, I only can see limited network configuration setting, for example I can't see DNS setting. how can I see all network setting on the phone?
I've already check enable setting on the phone in CUCM.
any suggestion would be very appreciated.
Alex
mightyking
Level 6
Level 6
Enter the IP Address of the phone in to a brwoser then click enter. You will see all you need regarding network configuration for the phone.
MK
thanks for the quick respond, is there any way to see all the config on the phone?
thanks
Alex
You can press the setting button which can be found on the right side below the question mark button on the phone. Then select option number 2 which is "Network Configuration".
MK
