Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
limited setting display
Hi All,
I am using CUCM 7.0. in the IP phone, I only can see limited network configuration setting, for example I can't see DNS setting. how can I see all network setting on the phone?
I've already check enable setting on the phone in CUCM.
any suggestion would be very appreciated.
Alex
Silver
Re: limited setting display
Enter the IP Address of the phone in to a brwoser then click enter. You will see all you need regarding network configuration for the phone.
MK
thanks for the quick respond, is there any way to see all the config on the phone?
thanks
Alex
Silver
You can press the setting button which can be found on the right side below the question mark button on the phone. Then select option number 2 which is "Network Configuration".
MK
118
