Limiting end user making no of calls per day
I was wondering whether i can implement the below feature in CCM 7.1
Requirement: I want to restrict some users so that they can'y make more than 100 (100 is an imaginary value, it can be of any numbers) calls per day.
Kindly suggest.
Rgds,
Partha
Re: Limiting end user making no of calls per day
CUCM has no way to do this. The only record it has from calls is CDR.
You would need to look into TCL scripting and use H323 for this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Can you kindly elaborate on how to achieve this using H.323??
Rgds
156
