Community Member
Limiting number of calls on SIP Trunk
I set up a SIP trunk between CCME 3.2 (on 1841) and CCME 3.3 (on 2611XM). We've only 128 kbps of bandwidth. Use G729r8 with RTP header compression.
Does someone knows how to configure a limitation of simultaneous calls that could be handles on the trunk ?
Thanks in advance.
1 REPLY
Community Member
Re: Limiting number of calls on SIP Trunk
hi,
Read section Max-connections from below link :
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/voipsol/cac.htm#77490
let me know if that helps.
Jolly
134
